Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 03-11-2014, 01:19
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: pic: MOEnarch Swerve Drive
I would consider changing the location of your digital encoder for a couple reasons.
First, as you tension the belt by moving your cim, it will change the engagement on the Digital encoder.
Secondly, generally speaking those things don't appreciate a lot of side-loading.
Third, if your belt slips, your wheel will no longer be aligned with the encoder reading.
I'd consider a small lightweight bracket that places it directly over the primary shaft of the module itself, so you'll always know the true position of the module. This also relieves any side-pressure on it, and it can be coupled with something as simple as surgical tubing. It will probably be a wash weight-wise.
