Go to Post that....was more far-fetched than the tennis ball I threw for my dog earlier today... - TeknicllyInsane [more]
Unread 05-11-2014, 11:03
MrForbes MrForbes is offline
Re: pic: 1156 Off season Fisher-Price gearbox
Over the years we've made a few of our own FP gearboxes, for use in applications where the motor is not likely to stall. That means, powering a roller, not an arm. They have worked well, and we didn't make them nearly this fancy. The cooling holes are a good idea. The motor location needs to be set by the mounting hole for the motor pilot (the large area around the bearing, on the end plate, just behind the gear), and not by the mounting screws. The screws are just too small to be able to hold things in place on their own.
Good work, and it's a really neat project!
Unread 05-11-2014, 11:04
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Henrique Schmit is an unknown quantity at this point
Why is the gear distance adjustable? That will seriously lower efficiency and reliability in high-load applications if it's not done correctly.
The gear distance is adjustable so we can use different gear ratios with this gearbox. Yes, that's true, it would be less reliable in high-load applications, but we designed this gearbox for high speed applications, like shooting and collecting game pieces, so that is probably not going to be a problem.
Ready for the water games
http://i.imgur.com/QQXtifE.jpg
