Go to Post I think this thread needs a reminder that there's no h in mecanum. ;) - Lil' Lavery [more]
Unread 05-11-2014, 11:30
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: 3CIM Single stage shifter
I would personally opt for the VEXpro adapter:
http://www.vexrobotics.com/vexpro/ha.../217-3255.html
A little cheaper and a little longer.
Where has this been all my life?
Unread 05-11-2014, 13:08
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Nuttyman54 View Post
The problem is that the reductions you get from those stages are to small to realistically do a direct chain reduction, so you'd need to add an additional gear stage...at which point you're back at something akin to the available COTS options. You're trading reduction for spread
The stages the OP has modeled are 18:60 and 24:54, which are 3.33 and 2.25 reductions, respectively.
The alternative gearing you propose to get the 2.27 spread (24:60 and 40:44) only give 2.5 and 1.1 reductions, respectively.
You could maybe do a 34:44 reduction instead of the 24:54 reduction, for a 2.57 spread (almost the same as an AndyMark Supershifter), but that still ends up awfully fast (20fps range) with a 12:36 chain reduction.
No doubt about that, it is NOT an ideal way to go. There needs to be a more reduction at the first stage to make this a viable solution. I was just trying to get the spread a bit greater.
Honestly, after using the original ball shifter for two years now, we would like to see a bit more spread than 2.27.
2.57 is probably closer to where we want to be, although even that may not be absolutely ideal either.
Ahhhh compromise, the bane of all things Engineering!
Unread 05-11-2014, 16:44
jman4747's Avatar
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
If you are willing to use 9-11 tooth sprockets from McMaster and Vex 28-33t plate sprockets you can get 2.92 with standard Vex Gears.
Fast: 30t CIM, 44t Ball Shift
Slow: 14t CIM, 60t Ball Shift
Final: 10t Sprocket, 30t Sprocket
#banthebag
#RIBMEATS
