Go to Post If you thought two alliances racing to tip the bridge in auto was exciting, wait until they play autonomous chicken on the center line. :D - Alpha Beta [more]
Unread 05-11-2014, 21:36
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
Re: pic: All Done!
Originally Posted by Twins Inc. View Post
Thanks! Its exciting to be able to have an encoder directly on a CIM, but without a shaft extension it might be tricky to put to use in this fashion. The encoder's instruction recommends removing the actual encoder no more then three times, and it is also very robust. But you are right, It take extra time to replace the whole unit if one part does fail.
We machined the part on a Centroid Conversion CNC, and added the mounting holes later on a manual mill.
I still love the idea, even though it takes more time to replace
