Go to Post thanks CD for being a one-stop, inspiration shop! - Michael Corsetto [more]
Unread 05-11-2014, 23:46
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: All Done!
Originally Posted by Twins Inc. View Post
The Counter sunk holes are actually mistakes The zero was a little off when it was first machined. The counter sunk allen-head screws are securing it to the CIM, and the two tapped holes are the same bolt pattern as the CIM, 10-24 to be used similarly for mounting.
Any reason you tapped them 10-24 instead of 10-32? I've found it's easier to standardize on only one type of size-10 bolt.
"The breakfast of champions!"
