Go to Post Imagine a world solely consisting of FIRST students. Oh the things that we could do. - Ryan Himmelblau [more]
Unread 15-11-2014, 15:30
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: Lightweight 8 CIM Shifting Swerve Drive Chassis
Originally Posted by Bryce2471 View Post
With good code, a rectangular robot, and 6 CIMs of torque; I think you would be able to do any swerve movement with a little scrubbing.
What makes you think that?
Unread 15-11-2014, 17:13
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Each wheel is independently steered, and if you had a 6 CIM 4WD tank that was 21" by 35", it would be able to turn in place without too much trouble.
This drive would be able to turn in place or translate without any scrubbing. It wouldn't have any resistance until it turned while driving. I think this relatively small disadvantage would be outweighed by the advantage in a pushing and driving straight.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 15-11-2014, 23:23
Ether's Avatar
Rookie Year: 1969
It sounds like you just moved the goalposts. But perhaps I am misunderstanding. Are you still saying that it "would be able to do any swerve movement with a little scrubbing" ?
Unread 15-11-2014, 23:35
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yes my intent was to support that claim. The only time scrubbing would be involved is when translating arbitrarily, and rorating at the same time. I believe that in that case, the 6 CIMs would be able to power though the scrubbing, given the gear ratio and width/length of the drive base.
Obviously, this is an opinion, and you can be sure without testing.
Unread 16-11-2014, 00:00
Ether's Avatar
Rookie Year: 1969
Yes my intent was to support that claim. The only time scrubbing would be involved is when translating arbitrarily, and rorating at the same time. I believe that in that case, the 6 CIMs would be able to power though the scrubbing, given the gear ratio and width/length of the drive base..
What wheel angles and wheel speeds would you use to make that bot pivot around, say, the front left wheel? (a common swerve maneuver).
Unread 16-11-2014, 00:34
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I would not call this a "common swerve maneuver" as I have only ever seen one robot get notable benefit from using it. Turning around one wheel is the worst case scenario for a swerve with front and back wheels tied because two wheels on the same side should ideally have a large speed differential.
Regardless, It should be possible to perform this maneuver with something like this:
https://scontent-a-sea.xx.fbcdn.net/...2a&oe=54DF1511
(and a lot of scrubbing)
Unread 01-12-2014, 11:50
Ether's Avatar
Rookie Year: 1969
Rotating around a point other than the Center of Geometry of the robot is a very basic swerve maneuver.
Indeed. I choose the front left wheel as the Center of Rotation to simplify the problem statement, and to pick an extreme case to try to clarify what you meant by "do any swerve movement".
https://scontent-a-sea.xx.fbcdn.net/...2a&oe=54DF1511 (and a lot of scrubbing)
If you are interested in exploring the physics of "scrubbing swerve", I invite you to participate (or just read along) here.
