Thread Tools |
Rating:
Display Modes |
Re: pic: new shoes
Re: pic: new shoes
Is there a law/rule against fundraising for you locally?
Re: pic: new shoes
No, but there are practical considerations in how much time we can realistically motivate our students to spend on fundraising, how much money that fundraising will actually bring in, and when it is feasible to do fundraising activities (time saved during our twice-weekly preseason meetings is not equivalent to time spent at events outside of those meetings).
If we save some amount of time on our preseason drive chassis (say, an hour or two) by having a pneumatic riveter, there is really no feasible way we can readily turn that hour or two into money given the constraints of our team structure. There are a lot of assumptions implicit in the utility calculation you've outlined. Those assumptions are valid in some contexts, but certainly not universally. |
Re: pic: new shoes
We bought the Harbor Freight riveter right before our 2014 season to save us time and energy... and broke it almost immediately. We ended up just getting another hand riveter and using two of those. Ate up a LOT of time in build season though - with the amount of rivets in the claw we probably consumed more than 1 build meeting total in extra time wasted.
That said, hand riveters get the job done just fine. With practice we could do things like change claw parts (drilling out at least 12-16 rivets and replacing them) in just a few minutes. |
Re: pic: new shoes
I was trying it yesterday and it wasn't working well at all, however out hose was leaking a lot so i think that was the direct cause. Once we fix/ replace the hose we can see how it works!
Re: pic: new shoes
Stephen, were you using the small yellow compressor directly or hooking it up to the wall-mounted air line? Send an email to Drake/Laverty to get a replacement host once you find the leak.
I'm not sure it's worth it to bring a compressor tank & air rivet gun to competition just for tread rivets, so we'll have to see what else we can rivet this season if the air rivet gun works so well we decide to go that route. |
Re: pic: new shoes
Re: pic: new shoes
Bringing a compressor to competition is complicated. It is a black hole of debate.
Re: pic: new shoes
EDIT: *Ducks* Last edited by cgmv123 : 18-11-2014 at 22:15. |
#10
Re: pic: new shoes
Care to cite a rule?
#11
Re: pic: new shoes
These aren't rules, but any rules I can cite won't apply next year anyway:
http://www.chiefdelphi.com/forums/sh...1&postcount=62 http://www.chiefdelphi.com/forums/sh...1&postcount=79 http://www.chiefdelphi.com/forums/sh...0&postcount=96 http://www.chiefdelphi.com/forums/sh...&postcount=118 http://www.chiefdelphi.com/forums/sh...&postcount=121 http://www.chiefdelphi.com/forums/sh...&postcount=123 http://www.chiefdelphi.com/forums/sh...20&postcount=4 http://www.chiefdelphi.com/forums/sh...3&postcount=15 |
#12
Re: pic: new shoes
And some events will not allow them because teams MIGHT use them to fill up their air tanks??? |
#13
Re: pic: new shoes
After some testing we found a large hand riveter (the style typically used for large rivets) worked better for putting nitrile on aluminium wheels than a air riveter. It allowed us to put a lot more pressure on the rivet when setting it compressing the tread around the rivet to create a secure attachment.
#14
Re: pic: new shoes
This is absolutely incorrect. There was NOT a rule in the books to forbid it. They can ask you not to run your shop compressor due to power concerns and you are absolutely not allowed to fill up your robot tanks from it. But there is NOT a rule saying it cannot be in the pits.
#15
Re: pic: new shoes
My those treads are worn. Good thing you know how to replace them, quickly.
---- Re: thread hijack to pit compressors -- at many events where I have volunteered, the people responsible for pit power want to know which teams have compressors. For example, at St. Joseph last year, we kept an inspector assigned to watch teams unloading and check for pit compressors. This was NOT motivated by suspicion that such teams might use pit compressors to fill pneumatic storage tanks before a match. It was motivated by a strong desire to keep pit power in service all the time, even if that meant juggling pit assignments so that the number of compressors on any one distribution circuit did not get too high. Fortunately, we did not need to move any teams or ask them to refrain from using pit compressors. I have been at events in past years where one or both of those things did occur. Most of the pit compressors I have seen teams use at FRC events were rated for 15A current draw. That in itself is not much of a problem; however, many of these things draw much larger surge current when they start (I have measured up to 50A for a split-second) and THAT can push an already loaded distribution breaker past its trip point, knocking out power to a row of pits. Then the roadies have to scurry ... ![]() |
