Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 17-11-2014, 10:47
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: 2169 'not so summer' off-season project teaser
Originally Posted by llamadon View Post
Thanks!
3. It is a tapped hole for 1/4 #20 thread. This coupled with the bolt and bolt holder create linear motion with the bearing blocks, allowing for tensioning.
Semantics, I know, but the notation is 1/4-20
Also, one thing that I might worry about here is galling on the aluminum threads in the blocks. It's rare with aluminum, but it sucks to say the least.
Galling is cold-welding between your screw and your nut material (in this case the aluminum) because the oxide layer of the aluminum wears away (this is why stainless steel fasteners can be a bad idea, the oxide layer wears away and they gall even worse than aluminum) .
I've only had it happen to me once before, but it makes the screw pretty much impossible to remove save with a drill.
Some ways that you can prevent this:
1. drill and tap your hole for a larger size and use key-locking inserts to put in a nice steel thread. This solves all problems and is my preferred solution.
2. Apply a PFTE-based compound onto the threads (or powdercoat / alodize/ anodize the material). Also solves most of your problems
3. use coarse threads with a loose fit (not really practical here)
Failing making any changes to the part:
4. Don't over tighten! Use a torquewrench and tighten to a low torque.
5. Tighten the bolt really really slowly. This keeps heat from building up too much.
