Go to Post Yeah, yeah...those who aren't spotlit, spotlight.... - Jessica Boucher [more]
Unread 21-11-2014, 02:59
nathannfm's Avatar
AKA: Nathan
FRC #3940
Re: pic: GBX-114 swerve with PTO
I guess putting them in brake mode would do the trick.
Yea, I figured whenever you sent them to an X configuration you would want to be breaking.
Originally Posted by Mike Marandola View Post
Nathan, I know you said that 365 did testing on diagonal vs. normal tread. Did you guys happen to test the tread sliding sideways as well?
Yes, I wrote up a procedure in that thread. Thats actually what started us doing the testing, we were getting pushed sideways more than we liked.
Unread 21-11-2014, 03:06
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Awesome. I will check that out.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Pushed sideways while in an X? That woule be very hard to do if you set the turning motors in brake as well; they are geared down 1:26 with a secondary of 30:84.
Unread 21-11-2014, 03:10
nathannfm's Avatar
AKA: Nathan
FRC #3940
Sorry, we did the tests last year on our 8 wheel WCD. With a swerve that has straight cut tread it should be just as hard to do as being pushed backwards. (I will have to think about how best to "break" with diagonal tread)
Unread 21-11-2014, 03:12
Thank goodness. I was thinking, "Oh god, did my numbers come out totally wrong!?"
They did, as a matter of fact. This is only geared for 20fps, sadly. I messed up the numbers in the calculator (again). Fortunately, the speed is easy to increase, but hard to decrease.
EDIT: I added a 3-position cylinder to the CAD, but for some reason these cylinders from Bimba are around 6" tall. So you can technically put on one here, but I would probably learn to live with this version.
Unread 21-11-2014, 03:24
nathannfm's Avatar
AKA: Nathan
FRC #3940
I'm confused, what's that have to do with being pushed while in X mode?
Unread 21-11-2014, 03:35
If you get pushed from the side while in x mode, then because the contact patch with the floor (ideally) is a line or thin rectangle, the pusher will torque the wheel sideways a bit like a caster. It seems like it would take a ton of force to shove those wheels back into a straight position, but it is doable. I'm sure that the robot will lift before that though.
Unread 21-11-2014, 03:59
nathannfm's Avatar
AKA: Nathan
FRC #3940
Theoretically it's a line, if your wheels and the floor were both hard and solid, ideally it's as large a rectangle as you can make it because with tread on carpet the physics class friction model goes out the window and surface area is quite important. But 45° wheels pushing from the side should be identical to pushing from the front. You are right though, it's quite hard to turn a (for us) 100:1 braked planetary gearbox. As for lifting, unless your bumpers are higher than your opponents there is no force that is going to lift your robot. Infact, if your bumpers are lower they will be pushing you into the floor a small bit, increasing your normal force and your friction.
Unread 21-11-2014, 19:00
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Out of curiosity, how are the side plates of your caster box attached to the turning gear that the robot is resting on?
FLL Team Future imagineers
FRC Team Mean Machine
Unread 21-11-2014, 21:31
Ah, caster box. That's a good name for it.
The turning gear is a modified vexpro 84 tooth gear. A big hole is in the center for clearance, and about 1/8" is cut out of the face of the gear (deburring would have to be done carefully on the teeth). Of the 1/8", there is a small pocket that sticks up which the caster box side plates drop in to.
The pocket is wallled on three sides and has screws on the bottom to connect it properly. The fourth side of the pocket is the big hole in the center of the gear.
