Go to Post Let's all try to get along, it isn't that complicated. - Joe Johnson [more]
Unread 24-11-2014, 19:33
Jared's Avatar
Jared Jared is offline
Re: pic: CV Robotics WCD 6wd Drivebase Prototype
Originally Posted by JorgeReyes View Post
I noticed how the 3 cims are really close to each other. How were you able to achieve this because I found that while its possible to get a small gap by using a smaller tooth gear, it wasn't possible to get such a small gap because you are limited by the bearing size (.375X.875 flanged bearing) which interferes with the placement of the cim motors.
The 0.375" ID 0.875" OD bearing used here is thinner than the plate, so it's okay if the CIMs overlap with this bearing. You should put the flange of the bearing on the inside of the gearbox where the CIMs aren't.
