Go to Post I guess the freshmen had to learn the hard way, never turn your back on a robot. - Bcahn836 [more]
Unread 27-11-2014, 11:30
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: paper: Belt Driven VersaChassis WCD - Step by Step guide
If you put in tensioners, you could mess it up. If you don't, you can't. A very minor tradeoff, I know, but it's worth noting. It's surprisingly easy to overtension a belt.
To me there's basically no benefit to not going 15mm, and the reliability is *much* higher. Even if it does work, why would you want to gamble on the edge of a safety factor with your drivetrain? All of our 15mm setups have been rock solid.
By the way, a good calculator for belt center distance is here. http://www.wcproducts.net/how-to-belts/ We have had good results with zero center distance added. Your mileage may vary based on your tolerances.
Are larger spacers on the wheels required if going 15mm?
