Originally Posted by Chris is me
Yeah. If you're using 15mm wide pulleys, you'll need roughly 1/4" more in spacers (6mm to be exact) for the wheel with an offset pulley. You may also need larger standoffs for the Vex 3-CIM Ballshifter. The other wheel should be fine.
You do need a lathe to make custom 30+mm wide pulleys if you don't want two 15mm ones, and you may need to modify the outer wheel shafts a bit (may not be enough room for the standard locking collar retension, haven't checked).
Would I be correct in assuming the same things apply to the WCP dog shifter? I do know that both pulleys should fit in with no problem, but I'm not sure if the spacer size would change.
