Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 29-11-2014, 00:24
Re: pic: 8WD CONCEPT DRIVETRAIN
Originally Posted by Dunngeon View Post
True, but traditionally 8WD setups have raised both the front and rear set of wheels to shorten the wheelbase length to promote turning.
With the shorter robots, it's possible to drive 6wd without a drop center fairly smoothly. With the further shortened wheelbase provided by the front wheel being raised, I'd imagine it's pretty easy to drive the other 6 wheels...... Although I'm still not sure exactly why they chose 8wd with only a single set of wheels raised.
Depending on where your center of gravity ends up on the final robot, you can adjust which wheels you raise/drop and by how much, because your frictional/scrub force will be greater in the areas close to the CoG. All about the weight distribution.
2012 - 2015 : 624 CRyptonite
Team Website
