Go to Post Id have to say, that is probably one of the most creative floats i have ever seen. then again, this is coming from a guy who hasn't seen many floats (disregarding the 32-bit ones). - Uberbots [more]
Unread 29-11-2014, 00:51
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Re: pic: 8WD CONCEPT DRIVETRAIN
Originally Posted by Abhishek R View Post
Depending on where your center of gravity ends up on the final robot, you can adjust which wheels you raise/drop and by how much, because your frictional/scrub force will be greater in the areas close to the CoG. All about the weight distribution.
My guess is it has more to do with the tilt/COM change that robots undergo when they are changing velocity and direction, rather than weight distribution and wheel friction.
(2015-?): 973
(2012-2015): 955
