Go to Post studies have shown that postive feedback works better. Driver should get a shock until he obtains target lock, then it stops. Performance incentive :^) - KenWittlief [more]
Unread 30-11-2014, 11:47
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Cim with Encoder CUI Inc. AMT 102-V3524
How much further out along the shaft will the CIM pinion be cantilevered?
The encoder is 9 mm thick. A CIM pinion (VP) is 19 mm long. The CIM shaft extension is ~31 mm past the pilot boss. So the encoder will fit between pilot and pinion, without pushing the pinion past the end of the shaft. However, it will be about 1/4 to 3/8 inch further from the front motor bearing than teams would typically put it, increasing the bending moment. In applications where bending a CIM shaft is foreseeable (I think a 254 mentor has posted about seeing that), this method of encoder mounting will increase the risk of bending the shaft.
Richard Wallace
since 2003
