Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Unread 30-11-2014, 15:49
Joey Milia's Avatar
FRC #0192 (GRT)
Re: pic: Finally Done!
Curious about the questions above.
And,
How you're dealing with the thrust loads from the bevel gear and pinion? If they gear isn't supported with thrust bearings you'll probably destroy the radial bearings you're using.
The cim shafts can move a bit in and out, do you have a way of making sure the pinion is in the correct place?
