Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 30-11-2014, 18:51
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Cim with Encoder CUI Inc. AMT 102-V3524
The boss plugs into the encoder plate though, which plugs into the gearbox. I'm not talking about changing that, just putting a bearing in the gearbox plate to make the cim not as cantaleivered.
Sorry I misunderstood your idea earlier.
So, if I am getting it correctly now, you would put a third bearing on the motor shaft, between the encoder and the pinion? Maybe a 608, with 8mm ID x 22mm OD x 7mm length. Then you'll have 31 - 9 - 7 = 15 mm left for the pinion and its retainer, so a standard 19 mm pinion would need to be cut down to about 12 mm. This will still be enough to engage a 3/8 inch (9.5 mm) gear tooth face. A little more demanding of axial gear alignment, with very tight axial clearances.
Edit: maybe leave about half of the 608's axial length protruding from the encoder adapter so it functions as a pilot for the gearbox? This would allow larger pinions (e.g., 14 tooth) to clear the pilot diameter, making gearbox assembly easier, while relieving some of the tight axial clearance problem.
Richard Wallace
since 2003
