Go to Post If I had a mul-let then I'd look like Andy Baker used to and that would be ba-ad, really ba-ad. - JaneYoung [more]
Unread 01-12-2014, 10:04
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
pic: 3 CIM WCD Ball Shifter CAD
Unread 01-12-2014, 10:06
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: 3 CIM WCD Ball Shifter CAD
Those ratios are just about perfect.
Have you considered trying to make the Cims or shafts removable to facilitate easy gearbox removal?
Also, you may want more than just the two holes in the WCD block to mount the gearbox to the tube. Two more holes higher up on the gearbox would add a lot of strength.
Unread 01-12-2014, 10:40
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
That is a great looking gearbox!
I have a few questions though...
1) How much does it weigh?
2) What are the actual gears that are being used? The tooth count would be good, no need for product numbers.
3) How do you plan on mounting the gearbox?
Unread 01-12-2014, 10:57
It is as if Bryce's and R.C.'s two minds are like one. All that's missing are wave washers and an adjustable CIM mount for multiple CIM pinion options. The standoffs are slightly nested into the side plates for extra alignment support, but that's probably optional if there are other supports.
This makes me wonder if we can simply replace the output shaft and output gears on the WCP gearbox with their ball-shifting counterparts to get something that works with minimal modifications.
Unread 01-12-2014, 11:14
Olin class of 2019
Why would you do that? What advantages do ballshifters have?
I seem to recall that ballshifters wear out faster ,but I could be wrong there.
Unread 01-12-2014, 11:23
Faster shift-on-the-fly. Yet I agree there are tradeoffs, and I don't me to imply I'm entertaining executing the idea, but rather mulling over its possibility.
Unread 01-12-2014, 11:51
I think the lightening on the plates is just a bit too aggressive. Reducing weight is nice and all but you still want to keep your gearbox rigid and strong. I would thicken the webs and probably add another horizontal web(s) between the edge and the bearing for the first reduction. Just seems like not a lot of support to me. If you're that desperate to save a couple of ounces, lighten the gears before you lighten the sideplates that aggressively.
I would also be concerned about how little you are supporting the top CIM on this gearbox.
Unread 01-12-2014, 13:16
I have my doubts about the press fit into the end of the ballshifter shaft in such a configuration.
Unread 01-12-2014, 13:40
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The Cims are already removable. (although not very easily) I've considered making the gearbox removable, but I haven't come up with anything slick yet.
It weighs 1.9 lbs without motors and 10.5 with them according to inventor.
First stage is 12 to 54, second stage low is 24 to 60, and second stage high is 40 to 44.
It's mounted with the standard bearing block and the two bolts the are out to the sides.
The VEXpro ballshifter has a small aluminum shifting rod that tends to wear out. In this design, we would make out own out of steel for longevity.
That's just how I roll. If we're already going to be milling out the plates, why not optimize for the lowest weight reasonable?
This uses a simple one piece output shaft. Machinable on a manual mill and lathe.
Thanks for all the great responses! Keep it up!
FLL Team Future imagineers
FRC Team Mean Machine
Unread 01-12-2014, 13:42
Can you post a cross section of the shifting then?
Curious how that assembles if you've replaced their setup.
Unread 01-12-2014, 13:54
What I am saying is that your weight right now is potentially lower than reasonable. As you remove so much material, the gearbox becomes less rigid, and stuff will deflect away from each other under load. The CIM mounting is especially concerning as the moment applied by the mass of the motor will tend to bend the pinions away from the cluster gear, weakening both of them.
There's no reason to lighten a gearbox so aggressively when you have all that extra material in your gears that serves so much less function than the material you've removed from the gearbox. You could still have a heavily lightened gearbox, with just more material and better motor support. You would probably even have a net weight loss if you faced the gears and drilled some holes in them well below the root of the teeth in addition to adding material to the gearbox.
Unread 01-12-2014, 14:09
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I don't see how the top motor is mounted less securely than the top motor of the WCP 3 CIM DS gearbox. In this design the plate is thinner, but the upper standoffs are closer to the CIM.
If I was going to lighten the gears, I would lighten them as much as reasonable too, but that is a different story.
Unread 01-12-2014, 15:02
Jared's Avatar
Jared Jared is offline
I agree with others who say that the top CIM isn't mounted well enough. Your gearbox might survive, but adding that extra support for 0.05 lbs gives you a lot more gearbox strength. The heavy CIM motor hanging off the end of the plate will cause the plate to deform, especially when your robot accelerates/decelerates really quickly during a collision.
If you look at many teams' gearbox plates, you'll notice that the plate outlines tend to be completely convex, rather than having little things sticking out. The outline is entirely made up of straight segments, and segments of circles that have their centers inside of the outline of the plate. This also adds a ton of strength, and requires the same size stock to machine from.
The top one is mounted in a weaker configuration because of the orientation of the mounting screws.
Unread 01-12-2014, 15:50
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
The two lower bolts on the gear box should be able to go through the tubing used on drive rail. You would drill a clearance whole on the outer wall and the correct size on the interior wall.
Unread 01-12-2014, 15:56
nathannfm's Avatar
AKA: Nathan
FRC #3940
It looks like one CIM mounting bolt on each CIM is blocked by the gears, and that this problem could be solved by slightly rotating the CIMs but this might just be becuase of the angle of the render.
In yours there is much less webbing at the edges of the CIMs. Particularly the top one where there it is best to have webbing near the bottom of said CIM as this will prevent the CIM from sagging. I would recommend adding a web between the top standoffs on the back plate which would cross over the lower face of the top CIM.
