Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
  #31   Spotlight this post!
Unread 02-12-2014, 00:57
nathannfm's Avatar
AKA: Nathan
FRC #3940
Re: pic: 3 CIM WCD Ball Shifter CAD
Originally Posted by Bryce2471 View Post
I think the WCP gearbox only has one web that goes vertically to the bottom of the CIM. That is what this configuration has as well. Here is a close up of the CIM mount:
https://scontent-a.xx.fbcdn.net/hpho...e9&oe=54D168FA
Ah, this clears it up, most of that webbing was not visible in the original render and that makes me much happier about the support of the CIM.
Originally Posted by Jared View Post
The biggest change you should make is using the 0.75" boss on the front of the CIM to help locate the CIM. It'll increase the positional accuracy of the CIM by quite a bit, and it'll make the part even stronger.
This sounds like a good idea but I would caution that you should know the tolerances of that boss and the tolerances of the equipment used to cut the hole in the plate. We made our first waterjet part ever a few weeks ago with a 0.750" hole for the boss and suprise suprise it comes back and the CIM won't fit.
Would this be all steel? I know the ball capture area is steel on the VexPro model presumably for wear reasons. Also, I know it would be pretty difficult to machine but I would recommend a fillet at the hex to round transition as that looks like its a pretty big stress riser.
Related to this component, if you make the hex shaft attach to the ball shifter with a pin or through bolt instead of making it one part it would make removal of the gearbox pretty simple. Just pull the pin, retract the shaft toward the outside of the robot and pull the gearbox either out the top or bottom.
For those reading who want to learn, more on pocketing in this great video: https://www.youtube.com/watch?v=wGmsnD0KQMs
Also, just to comment on that video I prefer the "sketch fillet" tool to the 3D fillet tool as it crashes much less, trims your lines for you, and contains all your pocketing features in one "Cut-Extrude". Also, if it crashes you are already in sketch mode to fix it.
  #32   Spotlight this post!
Unread 02-12-2014, 01:07
+1. Use the boss. If you just use screws, then the cim can wobble more than a couple thousandths and lower efficiency. The boss should be used.
We used 0.752" without problems last year, allthough it was sort of by accident- I plunged with a 0.75" end mill in place of a 5/8" and thought I screwed up. But it fit perfectly!
So plunging in with a good 0.75" endmill produces an almost-perfect hole, although boring or even better over-sized reaming would be preferred if you can manage it. They have 0.751" reamers on the market for a really good fit.
  #33   Spotlight this post!
Unread 02-12-2014, 01:46
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Thanks for the heads up.
The vex pro website says that ball shifter shafts are 7075-T6 aluminum.
I considered this, but I didn't want to cut a negative hex into the end of the shaft.
FLL Team Future imagineers
FRC Team Mean Machine
  #34   Spotlight this post!
Unread 02-12-2014, 01:48
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
The pressed in output hex shaft is. But the actual ball shaft is steel.
R.C.
MadTown Robotics Team 1323
  #35   Spotlight this post!
Unread 02-12-2014, 01:56
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Interesting. Is the small shaft that engages the balls steel as well then? I find it hard to believe that they would use one steel and the other aluminum.
Also, here is a picture of an updated version that uses some of the suggestions posted in this thread:
https://scontent-b-sjc.xx.fbcdn.net/...e4&oe=551455E2
Thanks for everything so far. Questions and comments are still welcome of course!
  #36   Spotlight this post!
Unread 02-12-2014, 01:59
R.C.'s Avatar
The small "plunger"/shifter shaft is currently AL, might see an upgrade in the Future?
R.C.
  #37   Spotlight this post!
Unread 02-12-2014, 02:16
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Lol
Do you know if vex did any tests that suggest the ball carrier needs to be steel?
My team built a ball shifter for our shooter last year. (I'll admit it's a different situation) We experienced that the ball carrier had the least wear out of the three shifter components.
  #38   Spotlight this post!
Unread 02-12-2014, 03:02
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Lol
Some teams saw extreme wear on their plungers this year.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #39   Spotlight this post!
Unread 02-12-2014, 03:16
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Originally Posted by Mike Marandola View Post
I know. I addressed this issue earlier.
I was not referring to that part in this instance.
the part I am talking about currently is what surrounds the plunger.
  #40   Spotlight this post!
Unread 02-12-2014, 03:33
Lead Bumper Mentor
AKA: Mike Marandola
Ah. I just realized that.
  #41   Spotlight this post!
Unread 02-12-2014, 10:47
I sometimes (often) fillet in 2D, but the advantage to this that I've noticed (especially if you save right before you attempt 3d fillets) is that you can suppress / delete your fillets, adjust your original design, and your pocketing is more likely to still work after the fact than if you trim and fillet in the sketch layer. It also takes a bit more work / time.
Seeing the support of the CIM in more detail makes me more comfortable in it - I guess it's just my personal preference to have a member follow the outer edge of the CIM to best support the face. You're probably good to go with what you have.
  #42   Spotlight this post!
Unread 02-12-2014, 12:59
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I'm sure that adding a member would increase strength, but after the revisions I posted, I think it would be unnecessary in this case.
  #43   Spotlight this post!
Unread 02-12-2014, 14:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
To each their own, but I would consider this very poor practice. It makes the part much less transparent to anyone else who may need to work on your design and is far less flexible, as mentioned by Chris.
If you need to fix fillets, like Adam displayed in his video, you can use the fillet tool to do face fillets that will bridge the intersection of faces where two fillets intersect. Then you don't need to sketch anything.
2001-2004: Team 100
2006-Present: Team 254
  #44   Spotlight this post!
Unread 02-12-2014, 16:26
Jared's Avatar
Jared Jared is offline
Excellent point. I made all our gearbox plates last year to somewhere between 0.750 and 0.751, and only one CIM motor we had fit. We found it interesting that our CIM motors that were 8-10 years old fit perfectly in the 0.750" plate, but the news ones all seemed to be a touch bigger.
  #45   Spotlight this post!
Unread 03-12-2014, 00:08
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
What gear sizes did you end up using on this gearbox?
