Go to Post Kudos to you IFI, for your continued support of FIRST and its stated ideals - Racer26 [more]
  #33   Spotlight this post!
Unread 27-02-2003, 23:20
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Suction cups will work good for the first few practice matches and maybe some into the qualifying but by the time finals hit that HDPE will look like a scratching post covered in dust, dirst, and oil. Everyones pro-suction point is saying they can withstand exert a huge force on a glass-smooth surface, chances are the HDPE will be more like a rough concrete. If teams still want to go with suction cups it seems logical to go with 20 small ones instead of 1 or 2 large ones to minimize the risk of trying to lock onto an area with a scratch.
Do you want to take the chance that during finals your bot trys to lock onto the joint between the 2 pieces of HDPE and another bot knowcks you off like you weren't even there?
Also Ramp-doms have to stay for nearly the entire 2 minuts and even if the scratches only allow a slow leak chances are the ramp-dom would have to re-attach every so often.
The best option is to put some _ _ _ _ _ _ _ _ breaks on the bottom of your bot and get a COF of about 2.0 or if your budget allows and you can find it get some _ _ _ _ _ which will give you a COF of about 3.5.
Friction brakes are more reliable and lighter.
pic: Team 870 Wiring Nightmare CD47-Bot Robot Showcase 15 02-03-2003 21:46
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
