Go to Post If by hazardous you mean thinking about robots 24/7, waking up at 2am in the morning to jot some ideas down, completely losing your social life, and staring at a computer until your eyes hurt, then yeah! :D - looneylin [more]
Unread 02-12-2014, 17:58
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Concept Drive
3620 ran 6 CIM 6WD with four 4" blue nitrile performance wheels and two 4" dual omnis. No drop. Handled like a dream in five events: two Michigan districts, MSC, CMP, and WMRI. Our drivers are hard on tread (like a good driver should be!) and we went through a couple sets per event. Even had to change omnis once. But no problems with control or reliability.
I am with those who recommend against drop-center in a setup like this.
Richard Wallace
since 2003
Unread 02-12-2014, 23:47
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
I would flip your gear boxes so that you are at least direct driving one wheel then running chain runs off of that. It would be more reliable and less chain. Also agree with everyone else on the drop center topic.
-Ronnie
Unread 03-12-2014, 01:07
nathannfm's Avatar
AKA: Nathan
FRC #3940
-Ronnie
Agreed, you could even direct drive all 4 traction wheels and only chain in the Omni, assuming you are not planning on a sprocket reduction. This would ensure popping a chain will never hurt you. Whatever the setup ends up being I would recommend having (possibly redundant) chains between all wheels on a side so that if you are lifted onto 2 or 4 wheels by another robot in a pushing match you will still have full 4 CIM power to the wheels that are touching the ground.
Unread 02-12-2014, 23:54
RonnieS's Avatar
AKA: Ronnie Sherrer
-Ronnie
Unread 03-12-2014, 14:27
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
-Ronnie
Thanks for the feed back. We are going to scrub the drop center and stick to the omnis up front. This has been extremly helpful. We will keep you posted on how it turns out.
Unread 01-01-2015, 17:25
Jrizo's Avatar
Here is the actual cad file I work better in 3DS max but I realized that some of the measurement's were off so I redid it in Inventor. I have only done the actual drive train and not the whole frame. The center wheel is driven from the front omni by #35 chain. The performance wheels will have blue nitrile on them.
https://www.dropbox.com/s/n4nnbleo11...b2015.iam?dl=0
Unread 01-01-2015, 18:05
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Why have you chosen to put the omni wheels up front? I would personally make the omnis at the back (seems like no effort at this point, just declare the other side front) to give whatever manipulator/etc the benefit of more fine control.
perhaps this is moot for more reasonably dimensioned robots
Unread 01-01-2015, 18:35
Jrizo's Avatar
The dimensions of the original drawing are off the actual dimensions are 32x24. I see your point about switching the front and back, we may just do that if our drivers can get the feel for it .
Unread 01-01-2015, 18:36
I am Dave! Yognaut
AKA: Brian Bray
Of course I made it super long to show the effect. for a robot that is of standard squarish it is indeed significantly less of a concern
