Re: pic: Concept Drive
I would flip your gear boxes so that you are at least direct driving one wheel then running chain runs off of that. It would be more reliable and less chain. Also agree with everyone else on the drop center topic.
-Ronnie |
Thanks for the feed back. We are going to scrub the drop center and stick to the omnis up front. This has been extremly helpful. We will keep you posted on how it turns out.
Here is the actual cad file I work better in 3DS max but I realized that some of the measurement's were off so I redid it in Inventor. I have only done the actual drive train and not the whole frame. The center wheel is driven from the front omni by #35 chain. The performance wheels will have blue nitrile on them.
https://www.dropbox.com/s/n4nnbleo11...b2015.iam?dl=0 |
Why have you chosen to put the omni wheels up front? I would personally make the omnis at the back (seems like no effort at this point, just declare the other side front) to give whatever manipulator/etc the benefit of more fine control.
![]() perhaps this is moot for more reasonably dimensioned robots . |
Of course I made it super long to show the effect. for a robot that is of standard squarish it is indeed significantly less of a concern
