Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 03-12-2014, 14:27
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
Re: pic: Concept Drive
Originally Posted by Ronnie314 View Post
I would flip your gear boxes so that you are at least direct driving one wheel then running chain runs off of that. It would be more reliable and less chain. Also agree with everyone else on the drop center topic.
-Ronnie
Thanks for the feed back. We are going to scrub the drop center and stick to the omnis up front. This has been extremly helpful. We will keep you posted on how it turns out.
Unread 01-01-2015, 17:25
Jrizo's Avatar
Here is the actual cad file I work better in 3DS max but I realized that some of the measurement's were off so I redid it in Inventor. I have only done the actual drive train and not the whole frame. The center wheel is driven from the front omni by #35 chain. The performance wheels will have blue nitrile on them.
https://www.dropbox.com/s/n4nnbleo11...b2015.iam?dl=0
Unread 01-01-2015, 18:05
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Why have you chosen to put the omni wheels up front? I would personally make the omnis at the back (seems like no effort at this point, just declare the other side front) to give whatever manipulator/etc the benefit of more fine control.
perhaps this is moot for more reasonably dimensioned robots
Unread 01-01-2015, 18:35
Jrizo's Avatar
The dimensions of the original drawing are off the actual dimensions are 32x24. I see your point about switching the front and back, we may just do that if our drivers can get the feel for it .
Unread 01-01-2015, 18:36
I am Dave! Yognaut
AKA: Brian Bray
Of course I made it super long to show the effect. for a robot that is of standard squarish it is indeed significantly less of a concern
