Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 04-12-2014, 00:19
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
pic: 3 CIM WCD Ball Shifter Second Edition
Unread 04-12-2014, 00:23
Re: pic: 3 CIM WCD Ball Shifter Second Edition
It looks like you added in an extra gear, bearing, and shaft in order to make this viable. Do you think there's a way to keep the two-shaft design like this? I can't really think of one.
With that i mind, I think I prefer your last gearbox a bit more.
EDIT: Yeah, not a lot you can do without switching to belt combination it looks like.
Unread 04-12-2014, 00:28
Knufire Knufire is offline
On the idler gear, you can make that a bearing bore gear instead of a hex bore and make the shaft dead instead of live so it acts like another standoff.
How/where are you mounting the shifting piston?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 04-12-2014, 00:31
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I was a little worried about this. I planned on this being a trade off between height and weight. Surprisingly, because the gears are smaller, and the plates are more compact, this version only weighs 0.05lbs more than the previous.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 04-12-2014, 00:37
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I could do that, but I think it's unnecessary, and it would require modifying the gear.
It is mounted to an aluminum plate that is stood off of the back of the gearbox, in-between the CIMs. I could post a picture if your interested.
Unread 04-12-2014, 00:39
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
You can buy bearing bore gears? No need to modify the hex ones.
If you still wanna use hex gears you can get some .250" ID x .500" OD Bearings.
R.C.
MadTown Robotics Team 1323
Unread 04-12-2014, 00:42
That's crazy good!
On dead axles, they do sell bearing bore gears, and it looks like you have something like a 48t or 50t gear on there. That would probably bump the weight to lower than what you had before.
Unread 04-12-2014, 00:52
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
That's crazy good!
It's a 40 tooth gear. I guess I'm not seeing how a dead axle design would add useful strength or shed weight. I might give it a try anyway though, because I could be wrong.
Unread 04-12-2014, 00:56
nathannfm's Avatar
AKA: Nathan
FRC #3940
While it seems convenient to use the CIMs as the nuts that hold the standoff through bolts on, having your gearbox fall apart when the CIMs are removed probably isn't a good idea. Converting that idler shaft to a standoff would help remedy this and save the weight of a bearing.
Also, if you are going for flat try for one where all the CIMs are in a line (or nearly so) recent 341 and 254 gearboxes come to mind.
Unread 04-12-2014, 01:25
If it's 40 tooth then you would have to modify, unfortunately.
You should reconsider the cim removal issue with the through bolts. Making heavy motors part of the frame is really awkward for assembly. Harder to put them in place, in addition to the regular mounting problems.
Maybe just making one of the cims have a different mounting hole pattern would work.
Unread 07-12-2014, 02:11
Oblarg Oblarg is offline
AKA: Eli Barnett
This. A thousand times this. This is my biggest issue with the WCP single-speed gearboxes; it's incredibly annoying.
"The breakfast of champions!"
Unread 07-12-2014, 02:34
R.C.'s Avatar
I'm not following here, the issue with Bryce's gearbox is that all 5 standoffs mount to CIMs so you can't keep the gearbox together without motors. The WCP gearboxes use two bottom bolts and 2 integrated into the CIM so it doesn't have this issue.
We normally do this (not our robot) and put in CIM's later. You had the gearbox fall apart in a similar WCD setup?
R.C.
Unread 07-12-2014, 03:11
AKA: Eli Barnett
If you use the bottom two standoff bolts to mount to the frame (non-WCD designs, such as a modified AM14U, are not necessarily compatible with the through-tube bearing block), then taking the gearbox off of the robot and taking the CIMs off of the gearbox does, indeed, cause the gearbox to fall apart.
Past that, simply removing the bolts to the CIMs with the gearbox still on the robot causes the spacers to fall out, which can be a massive pain if they're not in an easy-to-reach spot.
Unread 07-12-2014, 03:15
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Out of curiosity:
Why is doing this useful?
Why couldn't you do this with the gearbox design that I posted?
Unread 07-12-2014, 03:16
R.C.'s Avatar
Gotcha,
Wasn't thinking of a non-wcd case. We normally leave the bolts in the same spot and that keeps the spacers there, but this again is a WCD case.
R.C.
