Go to Post Sleep well Chief Delphi, because for the next 6 weeks, sleep is only for the weak. :D - ttldomination [more]
Unread 09-12-2014, 03:55
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: 3 CIM WCD Ball Shifter Dead Axle
Originally Posted by Joey Milia View Post
The PEM inserts are pressed into the opposite side of the plate from the bolt, they have a flange but the flush ones are pressed into the material flush which cold forms the material into groves in the nut. They can be sourced from mcmaster here http://www.mcmaster.com/#captive-nuts/=uy130o
GRT has used the standard ones in our GB for the past three years and the flush ones in the 2014 GB. You'll need a hydraulic press if the plates are anodized but if it's just raw aluminum an arbor press should do fine I think.
More info on flush ones here http://www.pemnet.com/fastening_products/pdf/fdata.pdf
and a lot more info on their website http://www.pemnet.com
Great. Thanks for the info. I'll be sure to look into it.
FLL Team Future imagineers
FRC Team Mean Machine
