Go to Post Inventions are not built using premade parts. People come up with new ideas, from different angles and with renewed enthusiasm. Playing the game is fun, building and designing is inspirational. - Steve W [more]
Unread 09-12-2014, 23:27
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: 3 CIM WCD Crazy Geabox
Originally Posted by Dunngeon View Post
How much ground clearance do you have? Assuming a 4in wheel
IIRC, (I'm not at my computer) it's got half an inch on a four inch wheel.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 10-12-2014, 15:06
nathannfm's Avatar
AKA: Nathan
FRC #3940
Why don't you like it exactily? I think a flat configuration like this at least from a total robot packing components standpoint is ideal, I wish there was a COTS option with a configuration similar to this.
Unread 10-12-2014, 17:11
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I am in love with the packaging as well, but there are too many compromises necessary to make it fit like this.
-The gear ratios are close together, and they're not really adjustable.
-You would have to take a standard 64t gear and cut a ball shifter bore in it.
-It requires two expensive bearings that are 0.75" id 1" od.
-two of the motors go through 1 or 3 stages of gearing, and the other goes through 3 or 5 stages of gearing.
-It's heavier than my other gearboxes.
It would definitely be cool to build one, and you wouldn't find a gearbox with a lower COG, but I think my other designs are a lot closer to ideal for my team.
Unread 10-12-2014, 20:22
As a side note, those bearings only cost a little bit on Boca Bearings, and you could use a bushing if you wanted to.
However, I see why you don't like this. Custom gears are tricky to machine without a softjaw or machinable collet IME.
Unread 11-12-2014, 00:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The cheapest I found them for was $25. Not super expensive, but that's $100 dollars per robot that could be avoided. We also don't have any experience ordering from Boca. Which is also not a deal-breaker, but it adds to the list of difficulties.
Unread 11-12-2014, 23:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It's a neat idea, if (as you noted), pushing too far unless you REALLY need that low profile. If it's that important, perhaps you could put one (or maybe even two) of the CIMs on the wheel side of the gear planes, either ahead or behind the wheel. It would limit the wheel size, but it sounds like you've already committed to that anyway. Oh, yeah, you'd have to wire or control the wheel-side CIM backwards.
