Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 12-12-2014, 09:23
pic: GBX-116, Drill press swerve drive
Unread 12-12-2014, 09:25
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: GBX-116, Drill press swerve drive
This looks really, really impressive. I've wanted to make an easy-to machine swerve for a while now.
I'm not sure if I would use sheet metal for the caster box. It's weak across the joints, so I'd be worried about my box doing a parallelogram. Cutting it from extrusion would be much stronger.
17 fps seems fast for a 4-cim. It'll accelerate okay, but I'd be worried about blowing breakers if you hit something.
12-14 theoretical might be more reasonable.
Pleeeeaaaaaase release the CAD for this. I really want to check it out!
Unread 12-12-2014, 10:15
It is very easy to change the speeds via the large top sprocket.
I will release the CAD soon, once I think it's complete. Perhaps later today.
Thank you!
Unread 12-12-2014, 10:44
Oblarg Oblarg is offline
AKA: Eli Barnett
You're really going to have an awfully hard time getting good enough tolerances for gear meshing with just "a good eye and a ruler."
"The breakfast of champions!"
Unread 12-12-2014, 11:16
Olin class of 2019
Yeah, I'd imagine this would have to be milled. Or at least the caster box.
Unread 12-12-2014, 11:20
nathannfm's Avatar
AKA: Nathan
FRC #3940
due to the lack of commercially available 3/8" hex bore sprockets. Hopefully Vex or Anymark will stock those eventually.
You feel my pain.
This is why MOE went away from Vex bevel gears on our final version. This, with This (375 hex hub) is the best we were able to find, its awkward but it might work better for you. I dont feel comfortable doing gear meshing on a drill press.
Also, what's that random gear on top for?
Unread 12-12-2014, 16:02
Originally Posted by nathannfm View Post
You feel my pain.
I considered those, but the width held me away. Looks like I'll have to switch over.
The random gear on top is because of the lack of 3/8" hex 1.875" bolt circle hubs, but AM has them os I'll switch over. I was hoping to be able to buy everything from just Vex, but it's fine.
Unread 12-12-2014, 19:50
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Very nice.
I thought the random gear on top could be used for the encoder.
Unread 12-12-2014, 21:55
Originally Posted by page2067 View Post
Very nice.
It could, maybe. But I would rather put an encoder on the CIM for simplicity.
Unread 13-12-2014, 02:57
Does anybody know if banebots gearboxes come with the long screws to put them together, or do you have to buy those seperately?
Unread 13-12-2014, 07:11
Gdeaver Gdeaver is offline
FRC #1640
They come with the screws. However, If you use some 6-32 hex stand offs and 6-32 screws, you can face mount it. Also this allows the motor to be replaced without total removal of the trans.
Unread 13-12-2014, 18:06
you have a picture of this method? Do you mean putting standoffs on the face of the gearbox?
Unread 14-12-2014, 08:39
FRC #1640
Only picture I could find showing them.
http://wiki.team1640.com/index.php?t...IX_Drive_Train
