Go to Post If there was no internet then somebody in FIRST would probably invent it. - Koko Ed [more]
Unread 13-12-2014, 11:50
Pravin N's Avatar
Pravin N Pravin N is offline
FRC #1351 (TKO)
Pravin N is an unknown quantity at this point
pic: Team 1351 Drop Down E-Plate
wyrzykowskij1's Avatar
wyrzykowskij1 wyrzykowskij1 is offline
FRC #2851 (Crevolution)
wyrzykowskij1 is an unknown quantity at this point
Re: pic: Team 1351 Drop Down E-Plate
That looks really good, it's definitely useful to have that. What are the dimensions of that robot?
Unread 13-12-2014, 12:15
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
[JOKE]10/10 Removable motherboard plate! (Wonder if anyone knows 3DGAMEMAN) [JOKE]
Are you sure this wouldn't get loose due to strong impacts?
Unread 13-12-2014, 12:16
Yeah, how exactly is the plate secured?
Unread 13-12-2014, 12:22
Pravin N's Avatar
FRC #1351 (TKO)
We will be using rivet nuts. There will be 6 rivet nuts on the hinge, and another 6 on the welded pieces of mounting angle.
Here is a cool video to show how rivet nuts work: https://www.youtube.com/watch?v=dkPhGIaPCVs
Unread 13-12-2014, 12:27
This is a pretty cool concept. Rivet nuts are awesome for stuff like this.
What material / thickness is the board? Since it's not doing much structural work you could probably do a relatively thin bit of polycarbonate or a composite.
Unread 13-12-2014, 12:43
The rivet nuts look cool! For the Crevolution design, the plates that the Jags are mounted to are lexan, and the one that the cRIO mounts to is 1/8 inch sheet mostly because the cRIO is heavy and I don't want to take any chances here. the cRIO is mounted on its side too, but I think with the roboRIO you could probably make them all out of lexan.
Unread 13-12-2014, 13:09
Pravin N's Avatar
FRC #1351 (TKO)
We are using 0.090 Alum, but I am sure lexan could work just as well.
Unread 13-12-2014, 23:11
BenDSterling's Avatar
BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
BenDSterling will become famous soon enough
Cool! I may just have to try this idea...
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
