Thread Tools |
Rating:
Display Modes |
#12
Re: paper: New Control Functions - Drive System Testing
Staged Brown Out when the battery voltage drops too low proceeds through the following stages:
Stage 1: 6.5-7.3v -PWM/CAN motor controllers/Relay outputs are cutoff, 6v power rail drops out - Driver Station displays “Voltage Brownout” - Servo power lost - Disable pulse sent to CAN motor controllers, turning them off. - Can result in robot stutter as motors pull the voltage low, get cut off, voltage rebounds, motors immediately pull voltage low again Stage 2: 4.5-6.4v - , GPI outputs go High, 5v/3.3v power rails drop out - Sensor brownout occurs, e.g., encoders! - Stage 2 persists until battery voltage recovers to 7.5v Stage 3:<4.5v - roboRIO drops out - <3.5v the VRM/DLink drops out Last edited by Mark McLeod : 19-12-2014 at 10:20. |
