Go to Post If Teflon-coated pans have a no-stick surface, then how to they get the Teflon to stick to the pans? - dlavery [more]
Unread 21-12-2014, 13:26
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Re: pic: Bit Buckets 2015 Offseason Drivetrain
Originally Posted by orangemoore View Post
It appears that some parts were not saved in the same place as the rest of the project and were left behind when put on grabcad. Most of these parts are spacers and things that are not important
What parts are missing for you?
I just looked over the GrabCAD model and it looks like everything is there. I used SolidWorks Pack and Go, so it should have captured all of the parts regardless of location.
Unread 21-12-2014, 13:37
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
This is the message I got. I looked through the folder and couldn't find the part.
http://1drv.ms/13s7hOI
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 21-12-2014, 14:21
Custom User Title
AKA: Cal
I re-uploaded the model; try downloading again.
Unread 21-12-2014, 14:46
AKA: Roger Moore
Is it just me or did the Download All button go missing. I now have to download all of the files individually.
Stronghold
Student 2013-2016
Unread 21-12-2014, 14:51
Custom User Title
AKA: Cal
Missing for me too. That's odd.
Unread 21-12-2014, 14:52
AKA: Roger Moore
Could it be a setting in the project?
Stronghold
Student 2013-2016
Unread 21-12-2014, 14:54
Custom User Title
AKA: Cal
I don't see anything.
Unread 21-12-2014, 17:21
AKA: Roger Moore
The Button is Back!
Stronghold
Student 2013-2016
Unread 22-12-2014, 03:11
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Very nice. Our team has had laser cut chassis for the past two years, but they are nowhere near as modular as yours.
Unread 22-12-2014, 18:13
Custom User Title
AKA: Cal
Thank you. We looked at your team's robots when we were trying to figure out whether or how a laser-cut robot would work.
Do you guys have any experience with wood gearboxes or bearing press fits? We're trying them on this robot but won't have much time to test them before build season.
Unread 23-12-2014, 02:32
FRC #1899
We've never done wood gearboxes, but bearing press fits work fine, you just have to make the hole a hair smaller than the size of the bearing.
Is your chassis held together entirely with T-slots? We thought those would not be strong enough, so we use wood glue for everything. It probably helps that you are using 1/4" plywood, rather than 3/16".
Unread 23-12-2014, 02:54
asid61 asid61 is online now
How small is "a hair smaller" for wood?
Press fits in metal are pretty precise. 0.001" smaller than the bearing is a light/ medium fit, whereas 0.002" is a heavy press fit, for the usual FRC bearings. Wood would be more forgiving on the size.
Unread 23-12-2014, 10:03
Custom User Title
AKA: Cal
Everything is held together with t-slots.
We've experimentally found that cutting the bearing holes .006" undersize compensates for kerf and gives a pretty tight fit. I imagine that this number varies with laser model and material.
