Go to Post Why assume a full trophy case and spreading the message of FIRST (mentoring rookies) are mutually exclusive? Team 16 supported 6 rookies this season and earned 5 banners - I am equally proud of both. - Meredith Novak [more]
Unread 22-12-2014, 13:47
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: pic: Swerve again, for fun
Originally Posted by Aren_Hill View Post
...would rather avoid mercury on the robot (sliprings).
Are there not suitable sliprings for this application which contain no mercury?
Unread 22-12-2014, 14:08
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
A few questions immediately pop up for me:
How is the CIM shaft so short? Isn't it against last year's rules to modify motors?
Where would you get the bevel gears, and how much would they cost?
What's the weight?
Other than that, it looks very good.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 22-12-2014, 14:54
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
By that definition, wouldn't it be illegal to cut/strip CIM motor wires to add connectors of your choice on the ends?
The RoboBees
Unread 22-12-2014, 14:56
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
R30 specifically allows wiring, mounting brackets and output shafts to be modified. That rule has been there for years, so I would assume it would stay.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 22-12-2014, 14:13
From the cut-out in the other picture, I'm having a hard time figuring out how the large turning gear is mated to the grey-ish ring that acts as the weight-bearing thrust bearing for for the entire robot. It seems like all of the robot's weight is hanging from this ring which is hanging from the gear?
Unread 22-12-2014, 14:14
Jared Russell's Avatar
Taking a year (mostly) off
A few years back I found it very difficult/impossible to find a non-Mercotac COTS slip ring that was simultaneously (a) rated for FRC current levels and (b) within single-components COTS cost limits. It is possible that you could make your own spring-loaded slip ring, but YMMV with inspectors/rules in a given season.
Unread 22-12-2014, 14:40
Data Nerd
FRC #0079
It is possible (now), I don't have the link handy but they do exist. It's for use in wind turbines so it's actually got three wires. I've also found a few on various websites that are rated for 30A continuous.
The Mercotac ones are far lighter though.
Unread 22-12-2014, 15:04
Kevin Ainsworth's Avatar
FRC #2451 (Pwnage)
It has to be the most compact and lightest swerve to date!
Professional grade designing, I looked through the entire design earlier this year and thought it was brilliant. We tried to design something totally unique but nothing we came up with was as elegant. Thanks for the inspiration!
Unread 22-12-2014, 15:14
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
What makes you say that? Do you know the weight?
Unread 22-12-2014, 16:40
+1. I have a swerve design exactly like this on my computer, except with a 2" colson instead of a 3.25" versawheel, ad it weighs a minimum of 5.3lbs. Still heavier than Bryce's swerve, albeit only very slightly.
Plus, making it into a shifting version requires a lot of weight unless you don't use a COTS shifter shaft.
EDIT: Of course, if anybody could make the design lighter it would be Aren. So it could be lighter actually.
Very nice swerve Aren. It's cool seeing your drives. Are you using a dead axle? Is it possible to flip the cim?
Unread 22-12-2014, 17:05
We can presume that Kevin from 2451 has a pretty good guess for how much it weighs when he says
due to
Showed this to Kevin on 2451 and he took off running and now has a fancy 2 speed version.
Unread 22-12-2014, 17:43
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Just curious, is there any way we can get our hands on the CAD files to take a closer look at the module? I know this may be a stretch but worth a shot too: If a team wanted to build this, would the spec sheet include all the parts that come together to make this?
Unread 22-12-2014, 17:57
I don't think theoretical weights are fair to compare. If the system isn't made and working, it doesn't matter how light it is.
I could go design a 4 lb swerve now, no guarantee it will work or hold up. Many of the recent designs posted aren't robust enough to survive a season (I think Aren's here would though, as he's fielded 5+ swerves at this point I think).
Unread 22-12-2014, 18:08
FRC #2451 (Pwnage)
Couldn't have said it better.
Unread 22-12-2014, 22:50
We're looking at a theoretical model right now, so it makes sense to compare theoretical weights. Kevin's theoretical weight for his shifting design posted a few months ago was ~7lbs IIRC, whereas Bryce's models for shifting designs weighed around 6.3lbs. Even if it wouldn't survive a season as in the CAD, there's at least 0.5lbs to play with to buff it up. And Kevin's design used only small steel miter gears, whereas this design uses much larger steel bevel gears.
Given that, I think it's possible that this weighs more than many designs posted previously. However, it is much more compact, and for many situations that can be more valued than the weight.
If you believed that none of the recent designs can survive the season, then you really should have said so ealier, when those designs were posted.
Also, I found this yesterday:
http://www.chiefdelphi.com/media/photos/34178
So Aren beat himself some years ago.
EDIT: How is the bevel gear constrained axially on the shaft? Does it depend on the wheel to position itself properly?
