Re: pic: Swerve again, for fun
What makes you say that? Do you know the weight?
+1. I have a swerve design exactly like this on my computer, except with a 2" colson instead of a 3.25" versawheel, ad it weighs a minimum of 5.3lbs. Still heavier than Bryce's swerve, albeit only very slightly.
Plus, making it into a shifting version requires a lot of weight unless you don't use a COTS shifter shaft. EDIT: Of course, if anybody could make the design lighter it would be Aren. So it could be lighter actually. Very nice swerve Aren. It's cool seeing your drives. Are you using a dead axle? Is it possible to flip the cim? Last edited by asid61 : 22-12-2014 at 16:47. |
![]() We can presume that Kevin from 2451 has a pretty good guess for how much it weighs when he says Quote:
Just curious, is there any way we can get our hands on the CAD files to take a closer look at the module? I know this may be a stretch but worth a shot too: If a team wanted to build this, would the spec sheet include all the parts that come together to make this?
I could go design a 4 lb swerve now, no guarantee it will work or hold up. Many of the recent designs posted aren't robust enough to survive a season (I think Aren's here would though, as he's fielded 5+ swerves at this point I think). |
Given that, I think it's possible that this weighs more than many designs posted previously. However, it is much more compact, and for many situations that can be more valued than the weight. If you believed that none of the recent designs can survive the season, then you really should have said so ealier, when those designs were posted. Also, I found this yesterday: http://www.chiefdelphi.com/media/photos/34178 So Aren beat himself some years ago. ![]() EDIT: How is the bevel gear constrained axially on the shaft? Does it depend on the wheel to position itself properly? Last edited by asid61 : 22-12-2014 at 23:25. |
This years game was hard on our swerve modules but they are still going strong. I would pick a robust module over a cute light weight module any day. So I say to those who have caded all those modules in the off season, Make them and beat them. Do they perform and survive? Then it is a good design. Until then it's just a concept. We made a CVT module this off season. Do we do it this year? I don't know. I'm leery of adding complexity to an already complex system. I guess it depends on the game. But, we made it and tested it. Made revisions and beat it. First has become brutal. Will 2015 continue this trend?
The larger gear in Aren's design might be larger but the smaller gear is much smaller. I would go off tooth size and not OD of the largest gear. Our actual module weighs in at 7.5 lbs with no additional lightening of the gears, etc. This is too be expected since all the steel screws weren't added to the CAD model. We'll post a video of it driving around just as soon as it is, should have it powered up this afternoon. |
#10
The weight comes not only from the teeth but the face of the gear I think, as well as the hub. As the diameter of the gear increases the area/ volume of the gear increases considerably. You actually made your module? Super cool! I'll be looking forward to seeing it driving. |
#11
Great looking swerve Aren!
When you get it working Kevin, it would be awesome to see a video of it working! |
#12
Example: I led the design on this module as well as the 2010 6 wheel swerve. |
#13
(And if I made that tiny module, the lightening pattern would've been way cooler looking ) |
#14
How did 6 wheel swerve work out? |
#15
also: Finalists at GKC along with Engineering Excellence, Semi-Finalists at Midwest along with Regional Chairman's Galileo Division Champions Never ranked lower than 3rd after quals at any regional or champs, overall season record of 36-13-1 sooooooo... *Fun fact, only 6-Wheel Swerve to ever be on Einstein |
