Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 22-12-2014, 15:19
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Re: pic: Swerve again, for fun
Is the weight of the robot sitting on the cim pinion? I can't figure out the wheel pivot bushing/bearing for this design.
Edit: I see the button heads now. Is that a silverthin bearing?
Unread 22-12-2014, 15:35
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
It's compact for sure, but I can't figure out the bearing design.
As far as I can tell, all of the vertical loads are taken by the CIM shaft (!), and I can't really tell what takes the horizontal loads. There's an upper steering bearing on the CIM shaft, but the only lower bearing I can see is the white ring below the steering gear and that doesn't have much radial contact. What am I missing?
