Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 21-12-2014, 11:56
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Under what conditions would one "lose a CIM"? In 10 seasons I have yet to experience a bad CIM or see one in person.
We managed to damage all 6 CIMs in our drivetrain at Waterloo last year. We were having issues with popping breakers, inconsistent performance and the CIMs getting very hot very quickly. When we removed each CIM from the gearbox we found their no load current was 7-10 amps versus 2-3 amps a stock CIM would have. Replacing all our CIMs fixed our issues.
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 21-12-2014, 12:33
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Low Profile Gearbox Front View
Are you using an odd size of retaining ring? I've never had this problem before with the ring catching on other gears, but maybe I've just been lucky.
It always happens to us. We can usually get it far enough out to wiggle it around the other gear, though.
Unread 21-12-2014, 16:44
I have right now no less than four cims sitting my garage. I took them home because they were burning up and were no longer used on the team.
Some grease on the insides brought them back to life, but it is possible if they heat up too much.
Unread 21-12-2014, 17:03
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Even though it is a lot harder to switch out cims, I'm still think I'm going to keep the cims where they are because chances are we won't burn a motor. As far as the cim pinions go, its doesn't require the gearbox take apart because I could just take it out and change it.
One thing that does concern me though is the ease of changing belts if they snap.
Unread 21-12-2014, 19:03
You have essentially guaranteed that you will now lose all of your cims during elims due to Murphy's Law.
But seriously, is it that hard to just add one more non-cim standoff? Two standoffs can hold your box together when swapping cims. In that situation, having through bolts to your cims is wise because it becomes easy to remove and add cims.
Unread 21-12-2014, 19:48
Andrew Lawrence
What precautions are you going to take to ensure that your 6 CIM drive doesn't completely die when it goes under 7 volts of battery during a pushing match or high acceleration and the PWMs cut out due to the new control system?
Unread 22-12-2014, 00:35
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
I'd guess that implementing low-voltage protection in code by either auto-downshifting at low speeds or decreasing pwm power as voltage approaches 7 would keep this from happening.
Still waiting on 234's full report to make a call on it.
Unread 22-12-2014, 02:13
Team Captain
Yeah I think we are going to make an automatic downshifting program but we will do more testing to see what works and what doesn't. Possibly a shift light on the driver station to know when to shift.
Unread 22-12-2014, 09:21
JesseK JesseK is online now
Sure, it isn't "hard". But why add any extra complexity to deal with a very rare case? Sure, you have a box of dead CIMs - but would the average 6-CIM team also have as many? Why not deal with it by ensuring less stress on the CIMs to begin with, which reduces complexity and increases reliability?
Unread 22-12-2014, 16:52
Team Captain
Does anyone know if its possible to use this with the WCP gearbox bearing block ( which is currently shown on this gearbox) and using Versablocks on the sides. In the versa blocks, the 1/8" drop is created by flipping the block around.
http://content.vexrobotics.com/vexpr...40122-Rev2.PDF
Based of the drawing, I am thinking I could make the center of the gearbox bearing block .940" from the bottom of the 2in tube and then use versablocks on the sides. Would this work?
Unread 22-12-2014, 16:56
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Yeah that would work I'm sure.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 22-12-2014, 17:46
Oblarg Oblarg is offline
AKA: Eli Barnett
Same here. It always catches, but I've never not been able to remove a CIM because of it.
"The breakfast of champions!"
Unread 22-12-2014, 22:58
Well, it isn't hard to add another standoff. You only need one more. It's a total of 0.05lbs on the robot extra. "Why not" is the question here.
It's good to ensure the safety of the cims OC, I'm just saying that's it's good to plan for the worst case. You can still plan for reliability and add a standoff to the gearbox too. Do both.
