Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
  #31   Spotlight this post!
Unread 12-23-2014, 09:25 PM
Jared's Avatar
Jared Jared is offline
Re: pic: Shifting Drivetrain with Transmissions
Here's an updated version with HSMXpress toolpaths: https://drive.google.com/file/d/0Bzf...ew?usp=sharing
Pictures:
https://drive.google.com/folderview?...&usp=sha ring
Free speeds - 15.81 high, 7.38 low
JVN 81% speed loss - 12.81 high, 5.98 low
3.25" versa wheel
The cost for everything (without CIM motors or the pneumatic cylinder) comes out to $730, assuming big aluminum pieces for the frame come for a reasonably priced local place.
  #32   Spotlight this post!
Unread 12-24-2014, 03:13 AM
Pictures:
3.25" versa wheel
Those are some really good speeds for 4 cim. Hope it works out for you if you build it.
  #33   Spotlight this post!
Unread 12-24-2014, 03:35 AM
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
For encoders,
A handful of teams (254/1538/973/1323 etc..) have just drilled a hole at the end of the shaft, shove an encoder in there, and zip tie the wiring down.
http://puu.sh/bSXmC/4694259cf2.jpg
I would atleast snap ring the sprocket side and use a bolt/washer on the other side. If you don't have the resources you could always just buy the VersaChassis hex shaft:
http://content.vexrobotics.com/vexpr...awing-Rev2.PDF
Are you saying that 254/1538/973/1323 don't have any kind of retaining system on the interior axle shaft besides the encoder? I've always thought the shafts should be at least snapring or e-clip retained. The picture shows some kind of piece between the encoder and shaft, but I'm not sure what it is.
(2015-?): 973
(2012-2015): 955
  #34   Spotlight this post!
Unread 12-24-2014, 03:38 AM
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by Dunngeon View Post
Are you saying that 254/1538/973/1323 don't have any kind of retaining system on the interior axle shaft besides the encoder? I've always thought the shafts were at least snapring or e-clip retained.
Sorry in the CAD model there is a groove for a snap ring but no snap ring (I get lazy sometimes!). But yes you need a snap ring on both sides of the shaft or snap ring + bolt.
R.C.
MadTown Robotics Team 1323
