Originally Posted by ttldomination
I saw the extrusions are available on AM, and most of it looks decent.
I was wondering, in the images and documents that show the V-Bearing in use, the bearings are attached to a base plate of some sort. Are there plans to provide that base plate + V-Bearings as a kit?
- Sunny G.
Yes, There will be a kit. The kit would include 2 bearings, the eccentric + concentric bushings, the mounting plate, and the 2 nuts/bolts you need.
The plates are in transit now from the machine shop, and will be available before kickoff. A late change was made to allow teams to use normal 3/8 bearings with the same plates and bushings to build a 254 style lift using regular 1x2 tubing as another option.
We are going to be posting a whole bunch of applications to
www.revrobotics.com over the next couple days.
