Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Unread 28-12-2014, 10:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Swerve again, section view
So the drive shaft goes through the large steering gear well off-axis? That's certainly different, but it saves a second set of bevel gears.
I still don't see how the robot weight is supported. The wheel supports its axle which supports brackets which support the large steering gear, but there I lose it; neither the cim bearing nor the planetary bearing appears to be oriented correctly to support the robot weight.
Unread 28-12-2014, 13:42
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
I'm still confused about this as well, but think the intent was that the discussion would stay in the other thread.
FLL Team Future imagineers
FRC Team Mean Machine
