Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
Unread 30-12-2014, 10:30
Jared's Avatar
Jared Jared is offline
Re: paper: New Control Functions - Drive System Testing
Originally Posted by Joe Johnson View Post
I'm not your typical beat up on FIRST type guy but this seems like a really poorly designed system feature.
In the first place it seems to me that a small amount of money together with some clever EE thinking could have allowed all critical brain functions of the FRC control system to remain alive well down to battery voltages as low as we'd like (e.g. 1-2 volts).
In the second place, once you've decided to go down the path of load shedding, this seems like a not very clean implementation. By going with "all off" rather than scaling you pretty much guarrantee crazy and unwanted behavior. A simple scaling reduction scheme would make these brown out events almost unnoticeable for the vast majority of teams.
In the third place, a prioritzed and scaled load shedding seems like the obvious right thing to do. Teams should be given a way to let the system shed load in ways that make sense for that robot at that time (e.g. run this function that provides a list of motors to turn off, motors to scale, and motors to leave at full power or to scale as a last resort...).
From the outside looking in, it seems like FIRST missed an opportunity to do the right thing here.
Dr. Joe J.
I see where FIRST is coming from with this decision. Last year at the championships, I saw tons of robots trip their main breaker, reset their main breaker, or suffer from having a very low battery voltage. The load shedding is likely an attempt to fix some of these problems.
That said, I've review our teams logs from the championship and one district event. We had matches where we would have been affected by this 7 volt limit. Toward the end of our matches, after running around in high gear, with the compressor running constantly, we saw the battery voltage hit 6v and below, and we definitely below 7 volts for a decent amount of time. This match was played with an older battery, which we had to use because of the number of replays/elimination rounds that went to three.
My solution would be to have the load shedding functionality be optional/adjustable. Teams who don't want to deal with running the system on the very edge of breaker tripping/resets can leave it on, but teams are welcome to (at their own risk) disable the brownout protection and deal with it themselves.
This is speculation, but the 7v limit may be set to prevent transients below 7v that the system is not fast enough to capture. I don't know how fast they're sampling for the protection or how fast the protection can react, but it may not be fast enough to react to the really sudden voltage drops that can occur when a motor suddenly starts. The cRIO could stay alive during fast spikes, but I have yet to see tests of the roborio with transients.
