Go to Post Yes, I'll admit it...I had a crush on Ken Leung when we all went out together for the college night in 2002. - Elgin Clock [more]
Unread 12-30-2014, 04:37 PM
Electronica1's Avatar
AKA: Alexander Kaplan
pic: 1086 Blue Cheese Legen-dairy Drive Mark4
Unread 12-30-2014, 04:38 PM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: 1086 Blue Cheese Legen-dairy Drive Mark4
Did you guys make any changes from last season?
Unread 12-30-2014, 04:42 PM
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
The Gearbox is integrated into the frame, we are using 4 inch mecanum wheels, we used two Colson wheels per module instead of one, we are using 8 motors, and we are using retaining rings.
Unread 12-30-2014, 04:56 PM
To add on to what John said:
1. When using 4 motors, it is lighter than last years system (It is actually geared so it will still work if we decide to not use the minicims)
2. It is now a single stage reduction rather than using a tough box nano.
3. The modules have gotten smaller because we are using 2 inch colson wheels.
4. The piston is now a 2 inch stroke rather than a 3 inch stroke with the ports rotated. This actually allows our frame dimensions to be much more flexible than last years design.
5. We had issues with last years system with the bolts on the modules backing out (especially at the rumble, where we had one bolt back out enough to prevent us from using the traction wheels after lunch). To fix this, we are switching to retaining rings.
6. The 4 inch mecanum wheel allow us to make the traction wheel even closer to the mecanum wheel, making the chain length even shorter.
7. The modules are now made out of 1/8th sheetmetal instead of 1/4th plate, allowing us to use our sponsors turret punch. This should be faster and more accurate than trying to manufacture it in house.
8. The frame has the battery box built in, in order to be more robust than last years system.
Unread 12-30-2014, 05:04 PM
wilsonmw04's Avatar
Coach
What Alex and John said.
Unread 12-30-2014, 06:35 PM
Excellence is Bliss
FRC #0111 (WildStang)
Although 1/8" material is pretty hefty, you're missing an opportunity to add essentially "free" stiffness to your frame members by only using L shaped metal pieces instead of "C" shapes.
I would recommend that you add a continuous bottom flange to every piece of sheet you have in this photo.
Also, if you do what I mentioned above, you could certainly use a thinner gauge of metal (like .090"), which would allow you to have less lightening holes. Your turret punch sponsor will thank you.
Unread 12-30-2014, 06:42 PM
wilsonmw04's Avatar
Coach
With the type of drive we are using, a bit of flex is a good thing. This is the 4th year we have used a frame of this nature without any notiable need for more stiffness.
Unread 12-30-2014, 06:47 PM
Excellence is Bliss
That's fair. I don't have much experience with mecanum. I didn't think about it initially, but now I recall hearing that having a flexible frame is important to making sure that all 4 wheels are contacting the floor.
Unread 12-30-2014, 06:48 PM
Originally it was a C frame that was .09, it was changed later in order to give the frame a bit more ground clearance (the location of the module pivot was determined by geometry, which ended up a bit too low to fit a bend on the bottom of the frame and still have acceptable clearance).
We have found this particular frame style to be more than strong enough for anything we will run into for frc.
Unread 12-30-2014, 06:54 PM
Excellence is Bliss
You're right. This is the fourth iteration, so you guys have certainly thought this through better than I originally gave you credit for, my apologies.
It looks really slick, and I like it!
Unread 12-30-2014, 07:45 PM
wilsonmw04's Avatar
Coach
sorry about the multiple replies. We appreciate any extra eyes and comments on anything we post. We have very little professional engineering support. I am always looking for experienced eyes on our projects. It's just that this was a very large discussion a few years back.
As for the cheese holes. We are Blue Cheese after all, it's a style thing
Unread 12-31-2014, 02:25 AM
Does the extra cim on each of the front wheels provide an advantage over just a 4 cim drive?
Unread 12-31-2014, 07:38 AM
Flywheel Police
I believe there is a miniCIM along with a CIM on each corner.
Unread 12-31-2014, 08:56 AM
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
That's a great looking chassis.
Do you install your mecanum wheels as rendered? It's backwards from a normal set up.
David
Unread 12-31-2014, 09:03 AM
David
Yea, I put them back in when I was trying to clean up our cad model to post it, and mixed it up. We will fix it for the season if we chose to use this system.
