Go to Post However I did tell my wife I wanted to lose 20lbs of ugly fat quickly. She told me to cut off my head. Go figure. - Ed Coleman [more]
Unread 31-12-2014, 18:48
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: paper: Cyber Blue 234 Drive System Test - Performance and Power
This is great!
I find it really interesting that on paper, the 4 + 2 CIMs are comparable, and sometimes beats the 6 CIM option.
Quick question, am I correct in assuming that the "Peak Amps - 1 Motor" for the 4 + 2 CIMS was a Mini-CIM? (as "Peak Total Amps" for 4 + 2 is higher than 6, but "Peak Amps - 1 Motor" is lower)
I'm not sure hard it would be to organise, but from that data I'd be really interested in seeing how more combinations of Mini-CIMs (say 2CIMs + 4 Mini-CIMs) stack up.
It seems that even though the CIMs are higher power, by operating the Mini-CIMs closer to their MPP they perform noticeably better. This implies that in some drive trains, Mini-CIMs would actually perform better than standard CIMs. However it should be noted that (assuming the same gearing form CIMs and Mini-CIMs) the closer you get towards the CIMs MPP, the closer you get to the Mini-CIMs stall condition.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
