Go to Post My opinion doesn't matter at inspection. - DonRotolo [more]
Unread 02-01-2015, 19:18
Michael Hill's Avatar
Re: paper: Motor Performance Analysis
This is pretty awesome. Definitely one of the most polished Excel spreadsheets I've ever seen, that's for sure. I'm curious, with the default settings in there, is that combining 4 CIMs with 2 MiniCIMs and 2 Banebots? I'm a little confused at why you would do that. Does that simulate a possible full drivetrain motor set as a single motor?
Unread 02-01-2015, 19:35
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
I appreciate the compliment. I actually spent a good amount of time with our user interface folks at work to determine the best layout and presentation of the workbook.
As for the default settings, I combined those motors primarily to illustrate the capability of the workbook. I don't foresee any practical example of needing to combine so much motor power, but it's nice to think that you could have a 2k Watt motor if you really wanted. I also loaded a couple of other examples into the workbook to illustrate various features and applications of the workbook. You'll find those, by hitting the open icon. I know the most common use will be to input a single motor type and determine the gear ratio.
In all cases (including when only a single motor is selected), the workbook functions by determining the equivalent motor specifications of the combined motor and then performs all the gear ratio calculations. When I save the design iterations, I simply save only the user inputted values as everything else is calculated.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
