Re: paper: Motor Performance Analysis
I appreciate the compliment. I actually spent a good amount of time with our user interface folks at work to determine the best layout and presentation of the workbook.
As for the default settings, I combined those motors primarily to illustrate the capability of the workbook. I don't foresee any practical example of needing to combine so much motor power, but it's nice to think that you could have a 2k Watt motor if you really wanted. I also loaded a couple of other examples into the workbook to illustrate various features and applications of the workbook. You'll find those, by hitting the open icon. I know the most common use will be to input a single motor type and determine the gear ratio.
In all cases (including when only a single motor is selected), the workbook functions by determining the equivalent motor specifications of the combined motor and then performs all the gear ratio calculations. When I save the design iterations, I simply save only the user inputted values as everything else is calculated.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
