Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Unread 02-01-2015, 19:49
Lexlukener's Avatar
Lexlukener Lexlukener is offline
Project Manager/Lead Engineer
AKA: Luke Buckner
FRC #4265 (Secret City Wildbots)
Lexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to all
pic: Secret City Wildbots Team 4265 Off-Season Drivetrain #1
Unread 02-01-2015, 19:50
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: pic: Secret City Wildbots Team 4265 Off-Season Drivetrain #1
Why was it decided to have the gearboxes in an non symmetrical position?
Unread 02-01-2015, 20:22
Lexlukener's Avatar
AKA: Luke Buckner
Well for one it is symmetrical it has origin symmetry,but to answer your question it is because if they were together it would be nearly impossible to remove the motors with the long bot configuration. Whereas you would then need to widen the bot, and we just didn't want to have a widebot.
Unread 02-01-2015, 20:48
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Why butterfly this year?
Unread 02-01-2015, 21:01
Lexlukener's Avatar
AKA: Luke Buckner
After driving the octacanum last year we realized there was a incredible amount of slippage with the mecanum wheels since we went from a 4" colson to a 6" mecanum rotating at the same speed. Since the only 4" mecanum wheels were provided by VexPro and it was found in our prototype where we used the 6" VexPro mecanums and the rollers were snapping like crazy so we didn't want to take the chance with the 4".So we switched to the 4" omnis from VexPro.
Unread 02-01-2015, 21:11
wilsonmw04's Avatar
Coach
You should look at the 4" AM mechs.
Unread 02-01-2015, 21:12
Tim Sharp Tim Sharp is offline
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
We experienced the same thing
Oblarg Oblarg is offline
AKA: Eli Barnett
Seconding this. They look really solid.
"The breakfast of champions!"
Unread 02-01-2015, 21:17
wilsonmw04's Avatar
Coach
Can you confirm the vex mechs you used were the late model and not the new model?
Unread 03-01-2015, 18:16
Lexlukener's Avatar
AKA: Luke Buckner
Yes in fact they were last years mechs and not the new ones
