Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 03-01-2015, 01:26
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
pic: Swerve Render and 2471 CAD Release
Unread 03-01-2015, 01:28
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: pic: Swerve Render and 2471 CAD Release
Is this using the easy to manufacture swerve drive model you poster earlier?
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Sorry it's really late, I've been working on it all day. Here's a link to 2471's 2015 CAD release:
http://goo.gl/CWnYWH
FLL Team Future imagineers
FRC Team Mean Machine
Unread 03-01-2015, 01:32
Looks very solid. You should try to test some of your offseason designs next offseason though, because if they worked that would be way cool.
Unread 03-01-2015, 01:34
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
What operation order did you use to manufacture the coax in the uper tube? did you re-position the tube for both sides? If you are not using a tornado boring routine like you probably used last year are you using a boring bar? Or are you using a adjustable reamer of some sort for the bearing bores. What are your tolerances on those? Are you not choosing to put in the lighting holes like the ones i did last year? They made assembly a lot easier.
