Originally Posted by Ideal_Nerd
We used 1/8 last year and it got beat up and our frame bent in on its self. We also probably cut a triangle pattern in to it to save weight. As of now if we switched to 1/8 we would save 8.6 lbs
I'm probably going to be the first of many to say that with the right type of bends in the right places using the correct alum alloy, You do not need to use 1/4" alum, or even 1/8" alum. If you have a chance, check out some of 148s CAD. 148 has been doing sheet metal for a long time and I am sure you can learn a lot from it. I sure did.
Give this a look.
https://docs.google.com/document/d/1...P1uGkje3U/edit
This is from Team 148 the Robowranglers
You sure are on the right track, just keep up the hard work!
