Go to Post OMG I'm a nerd! :ahh: - JBotAlan [more]
Unread 05-01-2015, 10:44
ouellet348's Avatar
ouellet348 ouellet348 is offline
PTC Engineering Group Lead
AKA: Alexander Ouellet
no team (PTC)
ouellet348 is on a distinguished road
Re: pic: REV Robotics Simple Lift
I like it. Doing simple things really well > doing a few things inconsistently.
Unread 05-01-2015, 12:26
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
This is a really good option for teams without a lot of resources. Being able to help cooperate will be very useful.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 05-01-2015, 21:19
asid61 asid61 is online now
I would recommend lifting the stack and skiding the previous tote underneath it to increase stack height and decrease elevator size.
Unread 06-01-2015, 09:47
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
Could you expand on that? I'm curious where you are saying to slide the previous tote.
Unread 06-01-2015, 10:04
You take the stack you are in possesion of, lift it up, and move into another tote. Then place your stack on top of the new tote, and pick the whole thing up from the bottom again.
Unread 06-01-2015, 10:09
ouellet348's Avatar
no team (PTC)
To clarify the tote stack lift:
If you lift the bottom tote in an existing stack, so long as your center of gravity is stable enough, you could move a stack of theoretically any height onto a single tote thus reducing the amount of height your elevator would require.
The trade off here is high loads and thus a more stable center of gravity is required.
Unread 06-01-2015, 15:46
MegaHertz_Lux
I agree with that method of lifting totes. What material would be durable yet flexible enough for the snapping side pieces?
Unread 06-01-2015, 18:27
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
It could be rigid, but hinged and spring loaded so that it can only bend upwards.
Unread 06-01-2015, 22:47
KaiserEric13's Avatar
KaiserEric13 KaiserEric13 is offline
FRC #0503
KaiserEric13 is an unknown quantity at this point
Just wondering if there is any point advantage to stacking the totes within the robot, or if there is any real advantage to stacking the totes inside the robot in general?
Unread 06-01-2015, 22:54
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Maybe being able to move stacks
Unread 06-01-2015, 22:55
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Stability for one. Keeping your CG closer to your drive base should result in a more stable robot. Less tippy.
Stack security for another. It may be easier to design a system within your robot to keep tote/containers from falling over when moving about.
Work Hard, Have Fun, Make a Difference!
Unread 06-01-2015, 23:01
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Greg,
Do you know if this was designed with one or the Bimba Cylinders that are available to us? We are mentoring a rookie team and this looks like a great option to get them started! Thanks!
Unread 07-01-2015, 00:02
COG. If your COG gets too far out the chassis (which, for tall stacks, is likely) then you risk tipping a litle bit when you accelerate or stop suddenly. If you tip even a little, you might knock over your totes.
Unread 07-01-2015, 08:18
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Greg,
Do you have an approximate lead time for the bushings and bearing plate shown in this design to arrive at AndyMark?
Thanks!
Unread 07-01-2015, 14:10
REVving up for a new season
FRC #2848 (All-sparks)
Originally Posted by MrRiedemanJACC View Post
Greg,
I don't know exactly what Bimba is offering for teams this year. The cylinders in this design are 1 1/6 bore 14 inches long. Technically anything longer than 13 inches should work, you would just be using more air per lift than you need. You could also put stopper blocks (pvc pipe) on the shaft to limit the stroke if only longer ones are available. The ones I used in the design were from Mcmaster http://www.mcmaster.com/#standard-air-cylinders/=vd6415
Originally Posted by aldaeron View Post
Greg,
Thanks!
All parts are in route to AndyMark from Texas, I expect extrusions, plates, bushing and all the parts to be in stock by the weekend at the latest. We will keep doing our best to keep up with demand. We appreciate everyone's patience with this, and if you have any questions I will always be available to help.
How far inside your robot is really a factor of how many totes you want to stack and what amount of control you want to have of the totes as you drive around. If you have them all the way outside your robot, making turns at fast speeds become problematic. The other reason why in this design I only did it half way (besides accommodating the Kit chassis) was to make it so you don't have to drive on the scoring platform when placing totes.
Greg Needel│www.robogreg.com
