Thread Tools |
Rating:
Display Modes |
Re: pic: Noodle Damage
That's very interesting. I now fear for the safety of the noodles!
See the blue box below G16:
We drove over one last night and it shredded it.
So if we absolutely cant avoid driving over noodlesk, we won't get points deducted, however, we should still try to avoid it as not to get dirty looks from the FTA
That said I would hope no one goes out of their way to run over LITTER if there is no strategic reason preventing them from going around. |
Based on this result, I'll bet we see on AVERAGE 1-2 destroyed noodles per match. Given a regional runs up to 200 matches each (practice + quals + elims), I hope all regionals are planning to stock about 400+ noodles for the event.
When we ran over a noodle with our robot from last year the noodle was not destroyed, roughed up where it was drove over but perfectly fine. It has versa wheels from vex though. I believe damage done depends a lot on the robot running over it.
Bunch of litter sympathizers the lot of ya...
But in all seriousness small bits of noodle bouncing around an electronics board not fun at all... |
#10
Has anyone given any thought about small pieces of litter getting into wheels, gears, and other small moving parts at the bottom of their robot?
#11
My team had the idea to take the bottom off one of those big industrial brooms that they use to sweep construction areas and attaching that on the frame of the robot so it just brushes the noodles out of the way.
#12
Noodle damage and robot damage that is caused by noodles is something to look out for this year! All teams and robots are going to have to be careful not to completely wreck every noodle in sight which will require some ideas on building to save the noodles!
#13
We could use this as a strategy. Think about if you pull a worm apart you get two worms. Now drive over one noodle you get two noodles and two points when you push them in the landfill.
