Go to Post We are here to both learn and teach. - Steve W [more]
Unread 08-01-2015, 23:19
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
pic: Test Board with New Control System and Talon SRXs
Source Code Here
Unread 08-01-2015, 23:21
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: Test Board with New Control System and Talon SRXs
Are the 4 bearing blocks in the corner the Plastic Clamping Bearing Blocks? (P/N 217-4155)
If so, how have they held up? Have you had any issues with them?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-01-2015, 00:10
sgosiaco sgosiaco is offline
FRC #5107
sgosiaco is an unknown quantity at this point
Could you possibly go into detail in how you got your usb camera feed working and what camera are you using? I'm having troubles getting a PS3 Eye camera working with a similar test bed setup.
Unread 09-01-2015, 13:46
GDB's Avatar
GDB GDB is offline
AKA: Garrett
FRC #2403 (Plasma Robotics)
GDB is a jewel in the roughGDB is a jewel in the roughGDB is a jewel in the rough
To be honest, I am wondering the same thing because we aren't sure rather to use the plastic bearing blocks or the aluminum ones (even though we have the aluminum ones already).
Unread 09-01-2015, 17:46
Joey1939's Avatar
AKA: Joey Holliday
I am not mechanical, but as far as I have seen they work just like the aluminum ones (The robot currently has 4 plastic and 2 aluminium) with no issues. My only recommendation is to make sure to put 2 bearings in each block. I wasn't given enough bearings when reassembling, so our wheels are angled with only 1 bearing in each block.
Unread 09-01-2015, 17:54
Joey1939's Avatar
AKA: Joey Holliday
Sure, first plug in the camera and open the roboRIO webdashboard. You should see the camera listed with a name like "cam0". If you don't see your camera listed there, it probably isn't supported.
Then in your code you need to insert the following lines in the initialization of the Robot (Assuming you are using Java or C++):
Code:
CameraServer server = CameraServer.getInstance();
server.setQuality(50);
server.startAutomaticCapture("cam0");
Make sure to replace "cam0" with the name of the camera found in the first step.
