Re: paper: Visual Center of Gravity Calculator
Instructions:
- Add whatever colors and weights to the list on the far right
- Use the excel "zoom" feature in the bottom right to help get around the worksheet
- Everything has range names--change formatting as you wish for everything that doesn't have a "named" range
- Everything is weighted equally across a color. So, if your arm stretches across across the page, each cell in the arm will carry equal weight. If one part of your subsystem is heavier than another, you can split them into separate subsystems.
- Each square on the map represents one inch
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
