Re: pic: Bit Buckets 2015 Prototype Drive Pod
+1 on the laser cutter. How long does it even take you to cut out your chassis? It's crazy how fast you guys can get stuff done with that thing.
It's a pretty neat tool to have; we can make 2D parts faster than literally any other team. Edit: At least as fast as any other team. Last edited by z_beeblebrox : 14-01-2015 at 23:26. Reason: See below post. |
Cough Cough |
we just have to assume that no one else does, because we only see 4183 posting pics of all these neat parts
Honestly because we have one now working without one would be extremely hard, if you have a lot of extra money (ha a first team with extra money) I suggest getting one, they are useful in most situations and cut time in design, fabrication, and programming by quite a bit.
Thats a neat looking encoder. Do you have any experience with it that you can share?
1899 makes almost fully-wood robots every year.
But the team probably wouldn't have the heart. |
#10
Why geared so fast?
Why not both? Never give up the mill.... |
#11
I would take the mill home.
![]() We might get rid of our old Grizzly lathe in favor of something that can actually cut steel in a few months, so a hobby machine might be coming my way already... |
#12
We're using Killough drive, so robot speed is 1/sqrt(2) wheel speed. We also like the simplicity of a single reduction gearbox.
I'm not certain; I think 60 or 75 W. |
#13
Neat drive module. I like the single reduction, very simple. What sort of fasteners are you using to tie everything together?
http://i.imgur.com/QCryxlE.jpg https://www.youtube.com/watch?v=2HHVwJ_C31M The side-panels took less than 2 min each to cut from 0.032 5052 Al. http://i.imgur.com/gU6AhRa.jpg Or a 4'x4' CNC router? All of these parts together took about 17min of cut time, most of which was in the pocketing. http://i.imgur.com/FgtZxiL.jpg Last edited by JamesCH95 : 15-01-2015 at 09:40. |
#14
Exactly what wood are you burning with your laser. I say exactly because I have access to a 160 watt laser and have tried cutting 1/4 Baltic birch and if it will cut depends on where I get it.
Some cuts real nice and some will only seem to cut to the glue line then just starts burning. So, if you have any details on what you are using it would be appreciated. Thanks |
#15
